inkadinkado
While I've refilled an HP 98 & 95 cart, I've not yet refilled a cart in my MP990 printer with 220/221 carts. I did like irvweiner's idea for a toothpick dip stick method to refill and wanted to run this by ink refiller masters to be sure it makes sense. I've read a lot here and I want to make sure I'm on track to successful refilling with my thoughts on a refilling methodology. Any ideas will be greatly appreciated. Here's my suggested method:
1. Reset chip of a flushed, dried OEM cartridge, or a cart that the machine has just warned is low on ink.
2. Place the original oem orange clip on the bottom to seal the outlet hole and use a rubber band to better secure the clip to the cart.
3. With an awl pry out the round ball in the cartridge inlet hole.
4. Take a toothpick and measure the distance between the bottom of the cart and up to about 1/8 inch to the top inlet hole.
5. Refill the cart half way up the reservoir side of the cart watching the ink rise in the carts clear window, then close the top vent hole above the sponge area with your finger tightly,
then fill up to the top of the clear window. Take another toothpick to measure the ink level and match the amount of ink in the reservoir to what the original toothpick (dipstick)
measurement shows. Add more ink if necessary.
6. Once a match of ink to the dipstick is accomplished, plug the inlet hole immediately with a lipped silicone (versus flat) plug.
7. Remove the rubber band and orange clip.
8. Set the refilled cartridge on a paper towel for about 5 minutes to be sure it does not drip.
9. If its the first time to ever refill: I will make sure the lipped plug clears the printers sidewalls. To do this, watch the print head seat in the center location and turn off the power to the
printer. Now, the print head is movable.
10. Now place the refilled, plugged cart into the machine. Move the print head left and right to see if it clears the sidewalls of the printer. If it does not clear using the lipped plugs,
remove those and use the flat plugs. (I'd prefer to use the lipped plugs if possible)
11. Turn on the power....print away.
