- Jan 18, 2010
- Residing in Wicklow Ireland
Just print as regularly as you can, daily if possible, that’s it..
After I got a small amount of this ink from pharmacist with some really nice test samples (thank you once more for sending the package) I was curious to see how this ink performs compared to the "klaria", which I used at first in my R285...
Octoinkjet.co.uk is now selling the high gloss Inktec Powerchrome K3 ink set, which is a resin coated pigment ink with a relatively high glossy finish.
Choose the inks that suites your needs the best, and don’t go worrying about sandblasting anything because you won’t be, it’s only ink you’ll be using.
If you choose pigment inks then you have to get a top load CISS because Marriott CISS (Bottom feed) just won’t work properly with pigment ink, good luck.
Happy Printing..
