Variation to German method
gigigogu
Well, instead of drilling the hole in usual place, I drilled it on the side of cartridge, at about half the distance between outlet port and spongeless compartment, angled toward spongeless compartment. It is a bit more difficult to drill the angled hole, but it allows to use a far shorter needle, also I found to be easier to insert the needle and place the tip in right place than the regular German method.
rodbam
Australia
Canon Pro 9000 mk2 & Pro 9500
What country do you come from so we can give your method a name?:)
ThrillaMozilla
Yes, this avoids:
(1) penetrating the sponge; and
(2) disturbing the contact between filter and sponge,
but it presents a shorter potential path for leaks.
The method has actually been suggested before, rodbam, although this is the first report I have seen of anyone trying it. :D
ThrillaMozilla
I almost forgot. Thanks much for trying that, gigigogu. Keep us informed how it turns out. :)
