Ron350
Testing print head flow out of the printer.
Once you have cleaned your print head using one of the many methods listed on this forum see how well it flows.
One method is to remove the intake port rubber seals and push on vinyl tubes.
The small ports take 5/16OD x 3/16ID tubing.
The large black port takes 7/16OD x 5/16OD tubing.
In the US most hardware stores sell the vinyl tubing by the foot and hopefully they do the same in other countries.
To test how open the print head screens and passages are fill each vinyl tube with distilled water (filtered water) and see how fast the level in the vinyl tube drops. To break surface tension you can put one drop of Windex in the water.
From what little testing I have done the water should flow through an unclogged print head in one or two minutes. Occasionally an air bubble will prevent flow but blowing on the tube will cure that.
If the water just sits in the tube I know there is still blockage some where between the intake screen and the nozzle chamber.
Just to be safe I place the print head on a damp sponge in a plastic container to prevent scratching any part of the print head.
Before placing any print head back in a printer I use caned air to dry out the eprom chip and circuit board.
Link to Manuchau post that made me think to post this.
http://www.nifty-stuff.com/forum/viewtopic.php?id=3960
The picture above is supposed to be showing where to place the canned-air to dry off the print head circuit board. I am paranoid about getting any fluid down in those holes and shorting out the eprom.
