Sudden death of my PRO 9500 ?
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
Operator Call Errors (by Alarm LED Blinking in Orange)
5 times
The print head is not installed
[1401], or it is not properly
installed (Print head
temperature sensor error
[1403] / Faulty EEPROM data
of the print head [1405]).
Removed the head, cleaned contacts, no avail
cls
Germany Hamburg
My deepest condolences.. switch to an Pro 100 or go Epson :)
palombian
Belgium
Wait a moment:
The blue led (power) is on, and the orange blinks 5 times again and again
So can be this too:
2-2. Service Call Errors (by Cyclic Blinking in Orange (Alarm LED) and Blue (Power LED), or
Alarm LED Lit in Orange)
5 times ASF (cam) sensor error [5700] - Sheet feed unit (QM3-1672)
The printhead moves as usual when I open the cover and all cartridges leds are lit.
Got it past the error once, but it only prints blank pages (and nozzle checks).
turbguy
Laramie, Wyoming
Canon i960, Canon i9900
Are the nozzles checks "normal"?
palombian
Belgium
It doesn't print at all.
At startup it comes in this situation:
- blue led steady on
- orange repeating cycles of 5 blinks
What I try do understand in the first place is what error I have:
- operator call error 5 times > print head not installed [1401], [1403], [1405], solution: install the printhead properly (what I already did twice)
or
- service call error 5 times: > ASF (cam) sensor error [5700], solution: sheet feed unit
When I release the rear paper feed plate (by slightly turning the cam), the printer does a paper feed at startup.
By doing this it once passed the startup without errors, but when I printed a photo, it did it without any trace of ink. Same for the nozzle check.
Printhead does all the regular moves and shakes.
Cartridge leds are lit and indicate the right condition (blink when I insert an empty cartridge).
I managed again to pass the startup (by the paper feed trick), and have now the proof it is the operator error :(.
Sorry Jan, but the print head is dead and there’s no coming back from that, I had exactly the same problem on mine, it worked one minute but not the next.
You didn’t do anything to make it go bang yourself it just happened for no apparent reason and now you have to suffer the cost of replacement.
I still think there is a major design flaw in all of these 8 plus cart print heads, there are too many of them expiring far too early then they should be.
@palombian head went not from a clog or from the use of bad inks but from everyday normal use as did mine; and I also got these conflicting error messages which didn’t make any sense, so you got my sympathy also..:(
palombian
Belgium
So what happened is that the head switched itself off and that nothing is wrong with the logic board of the printer ?
I refilled it maximum 5 times, about the same was done in it's previous life.
Maybe Canon considers a new head every 10 cartridge changes normal (the price is about the same) ?
Or has it something to do with refilling (overheating ?).
Or, as the manual states, the maximum life is 5 years ?
In that case buying a new head is useless since one day or another the printer will switch itself off.
>1-3. Product Life
(1) Printer
Specified print volume (I) or the years of use (II), whichever comes first.
(I) Print volume: 21,000 pages
(II) Years of use: 5 years of use
(2) Print head
(The breakdown is the same as the above.)
In a nut shell yes that’s exactly what happened and your logic board is fine, trust me on that, and a new head will have everything working back as normal.
Yes I know it stinks but until we can find out what is happening to these heads we’re at the mercy of Canon Inc, and you can be sure they won’t own up to a design fault issues.
I had filled my carts thirty or forty times so cartridge change is not in question and my head went in just under 4 years so it doesn’t have a set turn off time either.. :(
So what happened is that the head switched itself off...
What you imply is conscious programming of which there is zero evidence at this time. If found true would most likely cost Canon much more money from a seriously injured reputation and lost sales that would far exceed the profits from replacement head purchases.
The more likely scenario is a design or manufacturing flaw, where that flaw resides is open for conjecture.
palombian
Belgium
But that's what is printed :)
Let's read it then as an indication of expected life.
Based on an average of 500 "pages" per cartridge set, 21.000 makes 40 changes or 8 per year over 5 years.
Most amateurs print much less.
I can live with that.
Let's hope I had just bad luck this time.
