videobruce
- Nov 8, 2006
- Location
- New York State
- Canon IP4300 & Panny KX-MB271
This isn't another 'missing yellow' thread. (And sorry for the long background story)
I upgraded to a IP4300 from a i560 2+ years ago and up to 3 weeks ago have had next to NO problem refilling the tanks, nor with the printhead.
Then I got the dreaded 5 flashing orange lights error denoting a bad print head. I had two (what I thought were 'new') spares. I know different now.
I replaced the dead print head with the 1st printhead, ran some 'purge' pages, then did a manual alignment. All was fine for the most part. A couple of those cyan lettered test points were not the best, but everything else was good.
For two days.
Then I started to get streaking with the same tanks (and ink) I had been using for two years. I flushed the printhead out under the sunk using filtered water (from a under sink water filter). reinstalled everything and all was good again for a few prints, but the problem returned.
Blaming this supposedly 'refurbished' printhead, I tried my 2nd spare. That seems ok, thou not as good as what my original head was for 2 years (I believe that came with this used printer).
I ordered two 'refurbished' heads from two different e-bay sellers. Unfortunately they used the same source which is ISSCX. Apparently 50 to 75% of the dozen or so sellers of this printhead (QY6-006) buy from the same company. And guess what? BOTH of the replacements wound up with issues.
Anyway, now in in panic mode, I really don't want to upgrade again after only two years of use and the fact I also bought a spare IP4300 (both a a decent price), especially since looking over the reviews of printers with carts from the next two generations of carts w/ chips, I'd rather stay with theses carts & printheads ( printer) if I can get some that are actually good. My previous printer was a i560 which I had 2 for around 10 years.
Attached are pics of the problem. AFAIK, this seems to be an electronic issue. You can see light then dark stripes in each color, especially yellow. Black seems ok. Again, same ink thou I did try a fresh set of 3rd party pre-filled tanks I never used yet.
The 1st pic is the previous & current condition, the 2nd pic was what that purge pattern looked like after I swapped the almost empty dye black tank with a full one and before I ran a couple of pages of that purge pattern.
Input please.
For two days.
Input please.
