 - Jun 16, 2006
 - La Verne, California
 - Epson WP-4530
It sounds like you have an electrical problem in the print head that prevents the pigment black from working. Sometimes the same symptom is caused by the pigment black purge system not working but since you are getting black ink on the purge pad after a cleaning cycle, that appears not to be the problem in your case. You can try removing the cartridges and then the print head and cleaning off the contacts to see if that will get it going again but usually a new print head is the only way to solve an electrical defect in a print head.
