ipfken
I stupidly refilled pigment ink into the other black cartridge. Will it be OK to just run the ink out by using it on monochrome stuff and then refilling with correct ink? My printer is an ip4850. Thanks.
I agree. It is not worth the risk of trashing the print head for the relatively low cost of purchasing a new cartridge (or a used cartridge flushed and refilled if need be).I recommend that the cartridge wrongly refilled with pigment ink is discarded.
I've heard this so many times and it's not true. Pigment ink is used when you tell the printer you are using plain paper, it doesn't matter what you are printing, text, graphics or photos. The dye black ink is used for all photo papers. The dye color inks are used on all paper types both plain and photo.One section is used for pigment ink for text print only,
