Lost my HDD...need to reinstall printer drivers..have ?
Methodical
Where ever I lay my hat
As the title states. My HDD died and I need to reinstall Canon Pro 100 drivers onto the new HDD. Any pitfalls/traps I need to be aware of? I still have the original disc if that helps.
Thanks...Al
No. Disconnect the printer from the computer and then follow the installation instructions as if you were setting it up for the first time. If you have set the printer up for wireless or networked function then leave those settings alone during the initial installation of the drivers to see if it will work after installing the drivers. If not then you will need to do your wireless or networked settings over again from scratch.
All set up instructions found at https://www.usa.canon.com/internet/...et-printers/pro-100/pixma-pro-100?tab=manuals.
The initial install instructions are at http://gdlp01.c-wss.com/gds/4/0300008334/01/PRO-100_GS_U2_V1.pdf.
The setup guide for networked printers is at http://gdlp01.c-wss.com/gds/1/0300008421/01/PRO-10_PRO-100_NonPC_EN.pdf
