Hi, I recently started using the CD/DVD printing feature of the Pixma IP5000. I have run into a problem though. I'll try to outline what happened as best as I could.
After buying some full-hub printable Taiyo Yuden DVD-R's, I began to use the IP5000 to print. Everything was working fine.
I then decided to make DVD inserts as well, so I went to Costco and bought one pack of 8.5x11 Kirkland brand made in USA photo paper as I couldn't find any made in Switzerland one. I first tested using plain paper to see if the DVD inserts would look good, they did. I then started printing DVD inserts using the Kirkland Photo Paper. Everything seemed well.
Afterwards I decided to print on some more DVDs and ran into a problem. When I print now everything seems washed out. It seems like whenever red ink is required, it is using the yellow ink as a replacement. Also text seems faded. I'd try to post some pictures of the problem but I can't atm.
I decided to test out printing the same label but this time just using plain paper. It came out fine. It seems it only happened when I tried to print DVDs.
Anyone know what the problem may be? I'm using MMC branded ink.
Here are my settings:
For DVD inserts:
For Printable DVD
Here is an example:
This is how it was suppose to look:
For DVD inserts:
Code:
Media Type: Photo Paper Pro
Paper Source: Paper Feed Switch
Print Quality: High
Color Adjustment: Manual
Cyan: 0
Magenta: 0
Yellow: 0
Black 0:
Intensity 10
Enable ICM: On
Print Type: Photo
Brightness: Normal
Grayscale Printing: OFF
Reduce Spool Data Size: OFF
Printing Type: Borderless Printing
Vivid Photo: ON
Photo Optimiser PRO: OFF
Photo Noise Reduction: OFF
Code:
Media Type: Printable disc (Recommended)
Paper Source: Disc Tray
Print Quality: High
Cyan: 0
Magenta: 0
Yellow: 0
Black 0:
Intensity 10
Enable ICM: On
Print Type: Photo
Brightness: Normal
Printing Type: Normal-size Printing
Vivid Photo: ON
