Forced Pixma Pro 100 to Print
mawyatt
Clearwater Florida
Pixma Pro 100
Hi,
I am trying to refill my daughter's Pixma Pro 100 carts, and think I messed up the yellow circuit board when transferring to a cleaned CL8 cart (suspect I scratched a trace, can't see because I don't have a magnifying glass or microscope). We can't find any source for CLI-42 carts here in Flagstaff Az, so we'll need to order on-line. I will be leaving in a couple days and my grand daughter's need some prints for school. I tried using another Magneta circuit board (had a spare) on the yellow filled CL8 but the printer flagged it as the wrong cart (probably a good idea to prevent you from plugging in the wrong color cart in the wrong slot!).
I need to force the Pixma Pro 100 to print even though the yellow cart circuit board is not attached (the cart is in the slot though). I recall a method to do this but can't remember the details.
Any help is greatly appreciated,
Thanks,
Mike
Sorry Mike but your out of luck, hell will freeze over before you’ll get it to work without a proper cartridge chip.
There are still many places to get one, on line, a friend or neighbour, you could even get a compatible one and use the chip from that, you don’t need a new, a used one will still work if you can get one, don’t give up to quickly..
Here are instructions to remove a chip from a cart without damaging it.
http://www.printerknowledge.com/threads/canon-chip-removal-made-easy.5629/
mawyatt
Clearwater Florida
Pixma Pro 100
Thanks for the reply. I've swapped the boards on a few CLI-42 carts before without an issue, but Murphy got me this time!! Thought I could "fool" the printer thinking that all the boards were the same, used a board from a old spare dried out Magenta CLI-42, nope didn't work!!
