Force Pixma 6520 to print
Fabphoto
My resetter seems to quit working. How can I bypass the error message and force it to print when I know I have full carts?
thanks
What happens that is different from the normal? Be sd specific as possible.
If your resetter is battery operated then maybe the issue is need for a new battery. If you can open the resetter carefully, the button battery may then be replaced.
In the past, Canon gave the option to bypass the cartridge Empty message to continue printing. The instructions appear on your monitor in a Canon pops up window. If this option is not given then I do not know how you bypass the cartridge empty screen.
FYI - once you bypass the Empty Cartridge window, shutting down ink monitoring for that cartridge, then Canon may refuse warranty service.
