- Nov 3, 2004
- Location
- Bay Area CA
- CR-10, i560 ,MFC-7440N
One of the first things I do on my Creality printers is to replace the OEM fan duct with a "fang" dual-chamber duct. Not only should this help with cooling the part more evenly / better, I mostly like that it gives me better visibility to the hotend.
I purchased / printed this duct: https://cults3d.com/en/3d-model/tool/ender3-v2-dual-40mm-fan-hot-end-duct-fang
Printed it in glow in the dark pla: https://amzn.to/3g0VpuU
These fans (not as quiet as I wanted, but since they are bigger, I can reduce the voltage to make them quiet with the same flow as OEM): https://amzn.to/3G7QJxR
... and these awesome LED strips: https://amzn.to/3IMgq9c
Then I used OnShape to design an LED mount / arm:
... and it all comes together as seen in the images below. I split off the power from the heater-block cooling fan.
I especially like how easy it is to see the nozzle and how bright the light-bar makes it, without being in the way!:
