- Dec 27, 2014
- Germany
- L805, WF2010, ET8550
the entry level Epson photo printer A3 is the 1500W, a photo printer with dye inks, but there are reports that this printer is running without problems with pigment inks if you use refill cartridges. The heavy duty Epson printer for A3 is the Surecolor SC-P600 running with genuine Eppson pigment inks.
Canon has an A3 printer with pigment inks as well, a Pro ??? I don't know the exact model number, but the Canon users will help you with that. That model uses genuine Canon pigment inks, there would be no need for refill.
There is an abundant choice of media available from specialized shops, 200-300gr material is quite typical and comes in various finishes from high gloss to semigloss, silk, satin, lustre, to matte, or with a structured surface like fabric, metal gloss and other specialties. Availability depends on your country, I don't know where you are living. A DPI value should not be the deciding element, the print resolution of these printers is quite similar, and the numbers quoted by the manufacturers only quote a pretty high value for the dpi used to render a particular color within an image dot. These rendering subpixels are not accessible by your printing software, but only used by the driver/firmware.
