- Sep 10, 2007
- Location
- Laramie, Wyoming
- Canon i960, Canon i9900
My wife's MP730 started streaking badly with Pigment Black, even though nozzle tests showed a good grid.
Using refilled OEM carts with Hobbicolors PMT ink.
Cleaned the printhead with windex, and BLACK stopped working on nozzle check.....switched carts, same deal, even after several deep cleans via driver. Suspected purge unit problem.
Disassembled unit per:
http://newsquaremusic.com/MP730aug2008.html
All purge hose attachments found secure visually. Purge waste pads only 30% stained, but found deep pool of black gel in purge discharge well at bottom waste pad.
Popped peristaltic purge pump out of purge unit. Found black pumping tube totally clogged with black gel. Also had to ream out small hole iwhere black purge hose attaches to pump housing, as that small hole was clogged solid, too. Purge parking pad hose to pump was found clear. Cleaned all up.
Removed bottom waste pad and cleaned it until hot wash water ran clear. Pad was clogged with black gel.
Waiting for everything to dry before re-assembly. Will report back on results.
Wayne
Wayne
