Canon Ipf 6400 Error E141-4046 replacement of the purge unit
Enzo
Canon ipf6400
Hello, my Canon ipf 6400 plotter showed me an error E141-4046 that error represents the replacement of the purge unit I searched the web for that change and I did not find anything, I would also like to know which is the compatible I found the Canon QM3-7018-020 (QM3-7018-030) Purge Unit is for the equipment:
Canon imagePROGRAF iPF8300
Canon imagePROGRAF iPF8300S
Canon imagePROGRAF iPF8400
Canon imagePROGRAF iPF8400S
Canon imagePROGRAF iPF9400
You know if it is also compatible with the ipf6400 and if they have a picture or video of how to do the change of the piece.
For the moment what I did was reset the purge unit counter and the printer continues to print without any problem.
Thank you.
@Enzo, as far as I can tell the iPF8400 is compatible with your iPF6400, so both purge units should be the same, your biggest problem with any installation is to start, and get over the shock of removing the covering (Case), after that the rest is fairly simple.
To help you along the way you should take as many Photos as possible of every step you make and every screw you remove, that will be a great asset to you when it comes to reassembly.
A couple of pairs of Latex gloves will be essential because handling the purge unit in there can get very messy, good luck with you task, if you decide to take it... :)
Enzo
Canon ipf6400
Thank you then I will order the piece and take the risk of placing it, for the moment I was able to reset the counter to continue printing on what comes the piece.
Greetings.
