Brother MFC-9330CDW printed paper has a bumpy spot
zillah
Dear Experts
I have printer brother MFC-9330CDW when I print I am having the issue on a printed paper it has bump as in the snapshot below:
https://imgur.com/a/w6K6K9M
I tried to clean the drum but may be I didn't do it in a proper way as I am not sure the cause of the problem
https://imgur.com/a/3ek32wU
Please advise what could be the problem ?
Thanks
As the bumps appear more than once and at a fixed distance, the cause is most likely something stuck to a roller. Measuring the distance between two bumps and dividing by pi will give the diameter of the affected roller.
A service manual for your printer is found here: https://www.manualslib.com/manual/842730/Brother-Mfc-9130cw.html . See page 2-98 for roller diameters.
I hate to state the obvious, but did you check to see if they were like that coming out of the ream...:eek:
