I print pretty heavy with my printers, last night I had my ip4600 fail on magenta.
Some information:
Image Specialists Ink with a auto reset refillable cart. On a cleaning cycle, and a full test page print of red, the red dies half way through the page. Moving a known working cartridge into the mix produces the same result. (i blew through 2 complete refills doing "cleaning" cycles.)
The print head is clear (a tube right to the inlet screen shows me clear easy flow of windex, no clogs, nothing)
Again, it always seems magenta is the color that fails on all my older printers.
The pattern is the same on all printers that have failed, everything is printing fine, then BAM ! no magenta. It doesn't start to clog, it just stops. I'd like to say it's electrical, but if I run a cleaning cycle, I can get half a page of red before it stops printing. In some cases a cartridge purge will do, but when it finally dies, no cartridge will work. OEM or otherwise.
I am of the belief that this is an end of life failure. The amount of refilling that i do, in conjunction with the amount of printing, combined that it's 99% always magenta that fails. My printers always seem to die in the order they were bought in. It's usually a year of heavy use then they die.
I tried using refurbed printheads on my older machine, and they seemed to work only for a month at best. (they worked 100% out of the package) I've come to believe (and I may be terribly wrong here) that these machines have and end of life point. Where a new printhead will only last so long before they fail. In particular, it seems to be with models newer than the ip4300.
The ip4300's I bought died because I was inexperienced with refilling, When they died, it was obvious the printhead was failing.
The only thing that I can say is if the magenta ink isn't up to snuff, but if it *WAS* causing the printheads to die, how do I get half perfect test pages? If a printhead is dead isn't it dead??
The odd thing, it's *ALWAYS* magenta. And it goes from working to not working. No slow clog, just boom. Magenta is not printing at all. Nothing on nozzle check.
Some information:
