- May 29, 2007
- Ghent, Belgium
- Epson SC-P800,WF-7840,XP-15000
Hi everybody,
Would it be possible to calibrate my scanner using a target that has been printed with a printer profile that was firstly generated by scanning by my Colormunki ? So I make an accurate printer profile with my Colormunki Photo, with this profile I print a target taking care all the printed colours are within the range of my printer profile. Scan this target on my scanner and use the obtained data from the scanner to generate the scanner profile. And if so which target file can I use, because my Colormunki is compatible with the i1Studio that has the capability to calibrate scanners, but I do not have a dedicated commercial scan target (which is quite expensive).
