replied to the thread
Running almost 3 hours: the process is still hanging: Not sure what is causing it: it does not give an error that some data is wrong...
Sep 21, 2025
reacted to
Redbrickman's post
in the thread
How many of us are still refilling ink cartridges?
with
Like
Like NIfty I gave up on inkjet for normal office printing and bought a laser as I may not print anything for several weeks sometimes but...
Sep 21, 2025
I am struggling with the larger 247 patch target. There is not the same error as previous, but running colprof.exe and the system tends...
Sep 21, 2025
@Epatcola : that is a fantastic design you have made....making it possible to scan miniature patches as well. That will greatly...
Sep 21, 2025
reacted to
Epatcola's post
in the thread
with
Like
Here is a collar and 300mm rule for 10mm square patches. Rule and collar on your 247 patch target scaled by forced printing at 518 dpi...
Sep 21, 2025
E
Epatcola
Sep 21, 2025
yes indeed, likewise my i1Pro1 and i1Pro2 white tile also is bound with a seria number to the device and cannot be exchanged, because...
Sep 21, 2025
reacted to
Epatcola's post
in the thread
with
Like
I noticed the calibration cap has a serial number matching that which the device reports to the application. Our white calibration...
Sep 21, 2025
E
Epatcola
Sep 21, 2025
I will try to reread the target again, because maybe the problem is on my side. Normally the distribution of the test samples should be...
Sep 21, 2025
x64
Something with the gamut mapping the source ICC, when running colorprof with no mapping (no -S/-s) I can create an ICC with that dataset...
Sep 21, 2025
reacted to
Artur5's post
in the thread
Anniversary update on Standard Lamp Mark V..
with
Like
... or dislike it ...:p @The Hat, I expect you're planning to print the new 3D lampost in PLA ?. If you made it from ASA instead of...
Sep 21, 2025
Sep 21, 2025
Yes if you are able to prevent the new printer from getting draughts then ASA would work but I fear without an enclosure there would be...
Sep 21, 2025
Mine reads a white point of the tile: 91.22 -1.09 0.17 probably not a concern, as each tile is bound to each individual spectro.
Sep 21, 2025
