aqsa munir
- Apr 30, 2011
Respected Members,
I am using Spectrum Z-510 3D Printer in my University. It is giving following error and it causes/solution in troubleshooting manual of Z Corp.We have done all cleaning. It started but only printed 8 or 9 Layers , again stopped .Can you plz. tell me reason and how to rectify it.I will be very grateful to you.
Best Regards
Symptom/Error Code 1003
PRINTHEAD X ERROR
I2C READ FAILED FOR HEAD X
0 = W 1 = Y 2 = M 3 = C
In our Z-510 Machine , it appears like that
Printer Error 1003 (0)
I2C read failed for head 0
and on the Z-Printer Screen , this appears
Printhead 0 error
So Error is in Printhead of White or Clear as 0 = W
Greater Likelihood[/b]
Cause 1 : Print head not seated properly / contacts dirty
Solution :Clean print head contacts and Pogo Pins; Reinsert print heads .
Cause 2 : Bad print head
Solution : Replace print head
Small Likelihood
Cause 1 : Bad carriage cable
Solution: Replace Fast Axis Module
Cause 2: Bad pogo card
Solution : Replace Fast Axis Module
Best Regards
PRINTHEAD X ERROR
Printhead 0 error
Small Likelihood
