doom2
Hi Guys 2 simple questions i hope.
1, I still have some CISS Dye ink leftover from my old Epson P50 that used claria ink too.. Would the Black/Yellow/Magenta/Cyan be ok to use in my XP-700.
2, Pigment ink V's Dye Ink. Will my XP-700 be able to switch between the 2 ink types? IE a CISS Dye Ink setup for Day to day printing then when i want to do a Photo print to frame use a set of Pigment Ink carts then swap back to the CISS Dye set? The only experience i have had in pigment inks was they killed my Epson R285 from head blocks and that the normal heading cleaning solutions are not compatible with pigment ink.
Thank you
D2
Thank you
D2
