XP-215 firmware downgrade Help?
palibon
Epson Xp-215
HI
My inkjet is Epson Xp-215
by mistake I uploaded the firmware update is v OF25DB,
The printer no longer recognize CISS system
To return to an earlier version of the firmware?
I had a version of OF30DA
whence also download the firmware
So far it does not have the older firmware
thank you
Tigerman
Jordan
Canon MG5640, iX6840
Hi try do downgrade:
Turn off the printer.
Press and hold STOP + COLOR + Wi-Fi + ON buttons at the same time within one minute after printer is turned off.
Hold this buttons until all LEDs except power LED is ON.
Update devices list and select firmware then click update.
When update is completed all LEDs will blink.
Press STOP button to turn off the printer.
STOP - red triangle in the circle.
COLOR - color copy button with two blue sheets of paper.
May be this help
palibon
Epson Xp-215
OK thank you, I used to downgrade the firmware WICRESET XP-215
Does anyone not have a free program to reset the XP-215 Adjprog?
thx
sebcle38
sx-215
Hi, is it possible to upload an old firmware of XP-215 please ??
My one do not recognize CISS system after installation :( !!
Thanks a lot !!
palibon
Epson Xp-215
Hi Use Wicreset to downgrade to ver 0F08D4, kod 9,99%
As Palibon has noted the WICReset tool now has a firmware downgrade function for printers that have an earlier version.
Tip: Check the firmware version available via the utility is an earlier one that the one you already have on your printer to avoid embarrassing yourself by re-installing rather than downgrading.
I have zero experience of this functionality in the tool but the developers have assured me it works and costs a key (like a waste counter reset) so if the option is there it's a quick one to take.
Important to note though, any firmware update/change is very power sensitive so make sure you ensure your power isn't going to be interrupted midway through the process or you'll have a printer shaped brick for all the good it will do you otherwise.
