Why am I getting ink on the backside of prints with my Pixma Pro 100?
abaker
Print Lurker
Canon Pixma Pro 100
I print daily with my Pixma Pro 100. Two days ago I changed my ink cartridges and started to print. I am getting small blue marks on the back of my prints. I have checked the carts, no leaks. I even put in another new set of carts, but still have the same problem. I have run many bottom plate cleaning cycles. I have "printed" hundreds of blank "photos", just to run sheets of paper through the printer in hopes of cleaning out any ink. I also purchased a pack of printer cleaner sheets from Office Depot and run them through. When I run through 30-40 blank pieces of paper the marks gradually decrease and are completely gone by the end. But if I wait 10 minutes and then try to print again, the marks come back. Someone suggested to me that it might be the ink waste pads being full, but I have not gotten any error messages specifically about that. And this ink is clearly blue, I would have thought that if it was excess ink off the pads it would be black from the colors mixing. I did get a B200 error 3 or 4 times tonight while trying to fix the printer, which I have never received before.
I have 2 other new pixma pro 100s. One is complete with a new print head. The other is just the body of the printer, with no print head. Basically as I see it my options are as follows:
1. Try to figure out why this is happening and fix it.
2. Take this print head (has about 7000 prints on it) and put it in the printer with no print head.
3. Junk this printer and print head and start new with the complete backup printer.
Any advice would be greatly appreciated!!
If you have been printing lots of "borderless" photos?
Unplug the printer.
Raise the lid of the printer.
Now align the sheet as it would come through the printer. But with the bottomside showing. Take care to make sense of this part.
Now look at the paper path and the positioning of the ink marks.
Now search where the ink would come from. Use your finger if necessary. You will find the source of ink.
Looks like approx 4 or 5" from the right edge. of the sheet path.
Are you using prefolded paper stock to print?
Just use paper towels to soak up and dry off the ink.
If the source is on the sponge/foam, wet it down with water and then use paper towels to soak and dry it off. Continue with this as much as possible and then let dry and test again.
