Which Os 4 Argyll .icc Generation?
lowell374
FN10
CanonPro-100, E2000p, LexMark
I have 3 OS's within my box. Which one should I use to create an "argyll cms" ICC. Or should I install argyll within each of them and create the ICC profiles? Seems like a lot of extra work.
I'm planing to have both a display profile/calibration and many printer/paper/ink profiles.
The key code or calculations are all the same in the end. So choose which OS you are most familiar with and like to use. The results will be the same.
crenedecotret
Here is a thought lowell.... if one of these OS is Linux, you won't need to replace any drivers for your spectro in your windows install. ie: keep the X-Rite software on your windows install and keep argyll on your linux install.
You'll just need to be sure you reboot into the right OS to print your targets as the drivers would not be the same in linux, windows and OSX
