Paul Verizzo
- Apr 16, 2011
- Location
- Sarasota, FL, USA
- Canon ip4500, 9000 MK II, PRO-
First, I admit to being a hard core DIY'er, wanna do it myself, thank you very much.
With the continuing demise of swellable polymer papers, my primary goal is to minimize the rapid fading of dye inks on microporous papers, even Canon. As most of us here know, this is about shielding from gases, UV, temperature, and humidity. So, my thinking goes, make barrier shields, which might also include PVC/PET laminate. I have a fairly good background in coatings; I have painted cars, done the handyman gig, etc.
Some bottom line observations before I even get into the Florida sunshine tests, this is for microporous papers:
I have tried alcohol based coatings, methyl and ethyl with shellac. Deep blacks are rendered somewhat purple in moments. This is true for homebrew shellac or in the spray can.
Ditto water based acrylic.
Ditto true nitrocellulose type lacquer. Wow, it just peels the stuff off.
Only ordinary petroleum solvent products do not seem to effect the dyes. This includes cheap clear alkyd spray and expensive Krylon UV artist's varnish. However, all these clear/varnishes have issues with either clarity and/or UV resistance.
Ironically, the swellable polymer papers that inherently have a longer image life handle all of these coatings much better.
I'm thinking that dye on microporous might require PVC/PET lamination to provide perfect protection. I am researching this at many levels. I can tell you this, that so-called UV laminates mean that the laminate has some UV protection, it does not mean that the laminated piece is UV protected! With laminates, at least the result is uniform; liquid coatings have so many opportunities to get messed up.
Another consideration is humidity in the media. If humidity is a concern, why not minimize or eliminate it? No sense encapsulating water and dye. To that end, I've made a simple Big Ziplock/Silica Gel chamber to suck the humidity out.
Perhaps I've added life to swellable polymer papers, even if not my intention.
