Hi! Thanks four feedback!
For the printing issue: are you printing with the macOS printer dialog option or the the other built in print menu? You can change between those two in the settings window on macOS. It is pretty hard to nail this down. I tried back and forth to find a solution for this and for my Epson ET 8550 it seemed to work (I measured patches of a testchart I printed with different programms and in ChromIQ the results were the same). But I am not on Tahoe so maybe that can make a difference.
For the other issue: where did it go wrong exactly? Do you have the quality report saved? Which strips should it have flagged and which were actually flagged? Do you habe a screenshot or the log file maybe? This would help.
Edit:
This is Claudes take on issue 1 so far:
For Issue 1 (most useful first):
1. The Pro-1000 PPD + option list. Run and paste:
lpstat -p # to get the queue name
lpoptions -p <QUEUE> -l
1. and grab the PPD at /etc/cups/ppd/<QUEUE>.ppd. I want to see what Canon
calls its colour-matching / colour-correction option and its "off" value.
2. A captured "good" job. This is the gold standard. Put the queue on hold,
print a chart from Print-Tool (the working case), then inspect the spooled
job's options in /var/spool/cups/ (the c##### control file). That tells us
exactly which key=value Print-Tool sets that we're missing.
3. chromiq.log after a print using the native-dialog setting — it logs the
resolved printSettings and whether the no-CM lock verified, which tells me if
the PPD scan found Canon's option or not
Edit 2:
New update is on the way. It now pulls a few more strings to disable colormanagement that Claude considered useless before. I hope it helps. Please report back!
But for the guided refinement I have to know where it breaks exactly.
