Sharing Resetter between Pro-100 and Pro-10
t-flo
Canon Pro-100 and Canon Pro-10
Hello again PrinterKnowledge!
I'm wondering if there's a way I can get my Precision Colors Pro-100 CLI-42 redsetter to reset cartridges for my Pro-10/PGI-72. I've found that it actually already works on all the colors that are shared, but not on the new colors (CO, MBK, and R). I know the cartridges are slightly different mechanically but honestly I don't mind holding the bare PCB with the pogo pins against the cartridge.
No, and if it was that easy, then everyone would be doing it, you’ll need to get a pro 10 resetter and it will reset all the pro 10 carts for you easy…
t-flo
@The Hat Ok, I appreciate it, just figured I'd ask if anyone happened to have a firmware build or something that would make it work.
Is it ok if I ask for unclogging advice on the Pro 10 in this thread, or should I start a new thread? I've windex soaked twice and still having clogging issues with MBK and PBK. First soak I had issues with PBK, soaked again and PBK was fine but MBK was clogged. Annoyingly burning a lot of OEM CO while trying to fix this and waiting for my resetter to arrive.
t-flo
I just got a brand new OEM MBK cartridge today, ran two (normal) cleaning cycles later and unfortunately it’s still outputting anything from MBK. Should I keep doing cleaning cycles, back to windex soak or a third option?
Incidentally, is there anything in particular I should be doing to seal the cartridges while soaking the printhead?
Last resort..
You could try soaking the print head in a bowl of warm water with a bit of washing up liquid in it, and change the water several times a day, the next day dry the head thoroughly (Somewhere warm) then reinsert it in the printer and do a normal head clean then a nozzle check…
If you still have no ink showing up on the nozzle check, then it’s time for a new print head.. if you can see ink, then do the same soaking once again..
Just put the cartridge clips back on and give all the carts a good shaking..
