carburatediron
- Apr 17, 2025
- HP 200 Color Laser Printer
Take a look at the images below. I picked up a used Samsung CLP-680 with low use. Monochrome and color output are excellent, but I get regular magenta and cyan marks on every print. I suspect these are due to some sort of defect in the aftermarket magenta and cyan carts carts. (The black and yellow carts are Samsung brand while the magenta and cyan carts are True Image and LD Products, respectively.) I cleaned both carts' rollers with alcohol with no change to the print defects.
The simplest remedy is to purchase new carts. Before I do that expensive thing I figured I'd post to here. Maybe someone has had this issue before and can recommend a potential fix?
