Greetings. Sorry for the length of this message... I work for a Braille Transcribing company. We are entering the field of Brailled greeting cards. I am designing the cards using full color graphics and printed text. I then re-create the same image as a grayscale object and emboss it over the color image using a 3-D Braille embosser. The printed text is also recreated and embossed as Braille. I have been using 8.5" x 11" 110 lb white index paper; I send the stock through the color printer (using my old HP722C inkjet!) twice to get both sides printed, then I send the stock through the embosser - both sides. I end up with two single fold cards 4.25" x 5.5". I want a more professional looking card - one that is a "satin" finish on the outside, and matte on the inside, if possible. We are experimenting with Carolina CIS 8 pt print stock, but the inkjet black text smears too much, even after sitting for a week. We are shopping for a color printer, laser or inkjet, that will:
1. Print (feed) consistently on 110 lb, or 8 pt, coated card stock.
2. Produce a color image that is not just on the surface - by this I mean... we used an HP3550 Color Laser printer as a trial and found that: when embossed with the dots, the color "broke" at the top of the dots, allowing the bright white of the paper to show through the color image which ruined the image. My old inkjet produces a better image to be embossed over, so I am thinking we want a printer where the ink is absorbed slightly into the surface of the paper. Also, the multiple layers of color used in the graphics became "divided" on the output image with the HP3550. We have also received samples of the new Xerox "Phaser" 8500 color printer. The image is excellent, but again, the color surface breaks upon embossing, at least with the glossy paper stock they printed the samples on. We are awaiting additional samples. We are still thinking the inkjet might be the way to go...
3. Stability of ink - we want a finished product that doesn't smear if a teardrop falls. I know some of the new inkjet printers have smear-proof and archival inks.
4. Network-able with a Novell network. This isn't crucial.
5. I don't care about speed. We will not be doing a high volume.
6. No-fuss consistency and reliability is crucial. Clogged printheads doesn't sound very appealing.
So, with all the above in mind, could some of the experts out there recommend an inkjet printer/s that we could focus on, in the $400-$1000 price range. There are literally hundreds of printers out there but unfortunately most are not available for testing. If we could narrow the range down to 3 or 4 printers, it would be great. Thanks for taking the time to read this blurb. Any help or suggestions will be appreciated.
