Problem with Wincor nixdorf 4915xe
Mohd Fairul
Print Lurker
Wincor 4915xe, HP model dll
Dear Guys,
Do u know how to do alignment for wincor 4915xe?
Sometimes when printing, the results not center and sometimes alignment for each font not proper.
Is that the hardware problem? i already change the printhead, ribbon. But still the same result.
Thanks for your support.
BR,
Fairul
L805, WF2010, ET8550
I have the impression that Olivetti was the actual manufacturer of these 24 needle impact printers, you would have to look for a service manual, I found this one which appears to me quite close to
the Wincor model
http://sun-tech.ru/doc/SERVICE_MANUAL_PR2_PR2E.pdf
a scan of a printout would help to understand your problem better, it might be a coding/positioning problem. I just would guess, that there is a stepping motor moving the
printhead carriage, and there should be some coding disk to read the head position. These disks - optically or with small cutouts in a metal disk . collect dust, and the sensor gets confused.
