Pro-10 for $99.99
Think the Pro-100 was a deal?
Here this one for ya.
A pigment ink photo printer for $99.99 or whatever.
http://procam.com/canon-pixma-pro-10-wireless-professional-inkjet-printer
use PRO10 in promo code.
As of now it is working. Don't know how long it will last.
The last time this kind of stuff happened, it was the clear out of the Pro9500. This could signal the sunset of these models and the next one will probably be not as refill friendly. Could be the last chance.
If you read this and then pass on it and later on regret it, then we've seen these ridiculous deals before. it's real.
Fade tests galore on dye ink and OEM.
As Hat has suggested, if you are queasy about using aftermarket dye ink for fade reasons...then there is NO reason to not get this deal at 99.99. Refilling pigment ink while more costly than aftermarket dye will actually outperform OEM dye and still be less expensive. So that Pro-100 deal which might force you to use OEM ink to obtain longevity will be more costly than springing for a pigment ink printer.
One of my customers pointed me to this deal because he wanted a second set of carts.....and he also gets a new printhead and a waste ink pad (printer body) in the deal!
apetitphoto
Killeen, TX
Epson WF-3620 , Epson wf-7210
Just tried it and the discount brought the price down to $350. To bad - for me...
Update: I didn't see the rebate, which brings it down to about $99.
Emulator
Canon Pro9000 II
Groan, groan, from Europe.:barnie
plus the $250 rebate brings it to 100 bucks! I'm so tempted....
If it were me I’d get two, I wouldn’t wait, you don’t know what you’re missing, this is a great printer in every way, it’s so refiller friendly it’s just nuts...
@Emulator, well you might groan, these printers are going cheaper than a complete set of PGl-72 carts sold in the EU, it would be a great upgrade for your ageing 9000...:hu
tjk
Epson 1430
OK, in for two...darn it!
Question on the refills, do I need to empty/flush the OEM inks to use PC or InkOwl 3rd party ink? Or can I add new ink as the OEM carts go low on ink without flushing them?
@tjk, Run your first set of new carts to empty, rather than down to the low ink warning, then just refill with your preferred 3rd party inks and revert to changing all the carts when one becomes low, flushing is totally unnecessary, PC inks are a jump ahead for colour consistency...
  • Like
Reactions: tjk
