kestreltom
- Oct 20, 2019
- Location
- Albququerque, New Mexico USA
- Canon Pixma Pro-1 & Pro9000
I recently acquired a used Canon Pro 1 with a set of OEM inks all above 80% full. I live in the Southwestern US where it is dry, and I don't know how long this printer sat unused... it might have been years. The printer looks as if it has not seen much use at all.
The problem with the printer is that when powered up at about the 2 minute mark, it will display 8x alternating amber/white flashes:
https://youtu.be/bgMGMsXDCkI
The Canon My Printer utility reports a B500 "Support Code". At this point the printer is completely un-responsive: I cannot run a nozzle check; or park the print head so it can be removed and soaked/cleaned.
Someone on this forum graciously posted a pdf from their copy of the Pro-1 service manual that indicates that this 8x cyclic blinking of the Alarm and Power LEDs is a service call error that indicates an ink supply pressure problem. To wit:
Ink supply pressure error
[B500] (1) Ink leakage from and around the ink
supply unit: Check where ink leaks from, andwipe off the ink.
Perform the following according to the point of ink leakage:
- Re-install or replace the ink tank(s) or the print head.
- Replace the ink supply unit.
(2) Ink tank and print head conditions and ink tube connection:
(3) Cable connection (wrong or incomplete connection):
- Relay3 flexible flat cable (between the relay3 board ass'y and the logic board ass'y)
- Motor multi harness ass'y (between the ink supply pump unit and the logic board ass'y)
Re-connect the cables.
- Ink tank
- Print head
- Ink supply unit
- Relay3 flexible flatcable
- Motor multi harnessass'y
- Logic board ass'y
What I have done so far is open the ink tank doors by prying loose the sides of the printer and manually releasing the catch mechanisms. Then I pulled all 12 OEM ink cartridges and checked for dried ink and bent light pipes. The slots were remarkably clean - I did not see any evidence of dried clots of ink anywhere. The cartridges were in like-new condition and all of them weighed between 70 - 80 grams indicating they were nearly full of ink. I did see small droplets of liquid (not dried) ink in the vicinity of the sockets on the back of the cartridges, which leads me to believe that the seals are still in good shape. Very little ink spillage.
I would like to remove the print head so I can soak it in the "pharmacist's" solution.. Is there a way to remove the print head when the printer is un-responsive?
Thanks in advance for any help with this!
- Ink tank
- Print head
- Ink supply unit
- Logic board ass'y
