Roberto Smith
- Sep 24, 2017
- Canon
Hi all,
I have a Pixma Pro 10S and am wanting to do a few canvas based prints. I've been advised to choose Fine Art Paper > Canvas in the set-up, mostly because if I don't then the printer will use photo black not matt black and the results won't be as good. HOWEVER - when I try to select paper size A4 it won't let me continue and insists I need to use 11" by 17" as the only choice.
Has anyone else had a similar issue and how did you get around it? I assume I could just chose a different paper type such as Matt as this will print A4, but it seems a bit daft that the actual Canvas setting only works with one paper size and I can't set it to A4!
*edit* Ah okay I just realised I can actually set it to A4 but it has to have 30mm margins? I guess I can't print borderless on A4 Canvas in that case?
Thanks in advance
Thanks in advance
