PeterG
- Oct 7, 2018
- Prixma Pro 1
Hi,
I'm new here but have been looking through the old posts and can't find anything on this so have decided to ask, I'm sorry if this question has been asked before please send me in the direction of the post.
I've had a Pixma Pro 1 for about 4 years, no issues at all in that time, other than the 'there's no ink' when the cartridge still has some in it stuff. I've recently acquired an additional Pro 1 with an issue, the ink door will not release, what happens is this;
I've opened up the printer and was able, after pressing the blue switch, to trigger the doors to open by manually activating the switch inside. This lead me to think the solenoid was broken so I swapped the door with my working printer, no change. The door is therefore not the issue, it works on my old printer and not the new one.
This is where I'm at currently, I've taken the case off the broken printer to check the wiring but nothing is loose and I've no idea where to start with the control boards without a service manual.
My questions are;
Thanks in advance.
Peter.
- Power the printer on
- Printer does all checks
- Printer turns the blue 'ink' light on and flashes the amber light 4 times
- Press the ink button
- Printer makes all the correct sounds
- Printer then flashes the white and amber lights alternating until power switch is pressed
- The doors do not open.
My questions are;
- Is this a 'common' issue?
- Does it have a fix?
- What is the fix?
Thanks in advance.
Peter.
