NEW Service Tool SOFTWARE (waste ink counter reset) for CANON printers
narmenia
this is for CANON IP4760 4680 3680 1980 MP198 MX328 MP245 (according to the description of the file)
not sure if this can RESET other SIMILAR canon printers from different regions... i have successfuly reset the waste ink counter on my Canon ip4680
DOWNLOAD links:
UPDATED links
http://www.multiupload.com/D79Z6MF212
Multiupload.com
GUIDE
Assuming that your printer (ip4600 series) is already installed on your PC.
Reset can be done once your printer is on Service Mode:
a. Switch Off the Printer
b. Hold the Resume Button
c. Switch On and Hold the Power Button
d. Release the Resume Button
e. Press the Resume Button Twice
f. Release the Power Button
By this time your printer is in service mode already.
Run the Service Tool Program (Resetter)
Select ASA as the Region (for ASIA PACIFIC - depends on your location)
Set Clear Waste Ink Tank, select Main & Platen
Click Cleaning 1 (Printer will print)
Then Click Main and Platen
qwertydude
Is this real, will it work for the ip4600? If so this is a refiller's dream since it's been pretty much a throwaway item if your waste ink pad fills up on a canon.
SpideRMaN
WaW,
I managed to print the eeprom of the MP980 (which method was not possible without a service manual) tested on Win 7 x64
Some fonts are missing from the app that's why we see a lot of ????? in it ? . But I think it's a powerful Application and you can enable CD Printing on US Models beside other functions.
Is it possible to have any form of translation or help file ?
Thanks a lot !!
akgrown
SpideRMaN - would you mind offering some quick instructions on how to enable CD printing for an MP980? I just ran across this tool and want to make sure I use it correctly. I understand I will need the correct tray (G, I believe) to make this work, but am looking to you for instructions on how to enable the software/firmware side of things.
Thanks!
nanosec
bitsbytes said:
Does it work for an ip4500?
You don't need to use this for the ip4500, do a search on google for ip4500 waste tank reset.
nanosec
This is fantastic news!
I encourage everyone to grab these while they are still up.
This has basically increased the worth of the Ip4600 and ip4700.
Time to test and stock up on ip4600/ip4700!
SpideRMaN
You would Definitely get a full time job refilling those carts if you stock those printers (220/221 520/521)
blondu
thnx Narmenia.. finnaly this tool works.. with my canon ip 4600
slhsm
i think it works on mp270 too. i could print the eeprom and reset the eeprom. i couldnt do this before. thanks.
Latest posts
