Long Delay Until Printer Starts Printing
chzuck
WF Pro 4820
Recently I have noticed my Epson WF 4820 takes a much longer time to start printing a document than it use to. Any ideas on what I can check that may be causing this problem?
thebestcpu
Epson SC P900
chzuck
WF Pro 4820
Hi @chzuck
What type of document?
Mac or Windows?
From what application are you printing?
There was a recent thread about printing PDF documents that had a delay and the solution. Not sure that is your type of document yet here is the link to that thread:
https://www.printerknowledge.com/threads/delay-in-printing-pdf-documents.17255/post-147015
John Wheeler
Word document or mailing labels. Windows 11 Pro Printing from Word 2010
Thinking about removing and reinstalling software.
chzuck
WF Pro 4820
I timed the print delay today using a Word 2010 document. I did it from my desktop and a laptop, both wireless and the time from hitting print until the printer started was 34 seconds for both PCs.
thebestcpu
Epson SC P900
If your printer driver supports it:
  1. File → Print
  2. Select your printer
  3. Click Printer Properties
  4. Look for one of these options:
    • “Print as Bitmap”
    • “Rasterize”
    • “Send as Image”
    • “Advanced → Disable EMF spooling”
Enable it.
With some drivers and printers coming from Word (and other apps) it is sending more complex information to the printer that the printer firmware has to deal with. Using Print as Image moves that process to the computer/driver which can be faster. Worth a shot if your driver has that capability.
John Wheeler
chzuck
WF Pro 4820
SOLVED: I ended up removing and installing my WiFi settings on the printing and now it is printing as it used to. Something must have got messed up in the WiFi settings.
