1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: How to take pictures of gloss differential properly?
    CLICK HERE!
    Dismiss Notice
iP4300 Two-tone nozzle test
Discussion in 'Canon InkJet Printers' started by Gloryb, Jul 1, 2015.
  1. Jul 1, 2015
    Gloryb
    Gloryb Getting Fingers Dirty
    Jun 30, 2015
    21
    Texas
    Printer Model:
    Canon IP4300
    Greetings! I have had a Pixma IP4300 since 2007, used perhaps weekly, Canon ink only. Recently noticed horizontal bars running across color pictures/images, switching between darker and lighter tones.
    Ran standard cleaning, deep cleaning, nozzle tests. Only problem I noticed in the nozzle test is the first cyan bar is two-toned: darker cyan on top, lighter cyan on bottom.
    I removed and cleaned the print head with no improvement. Changed ink cartridge, no change. Contacted Canon, they said it was the paper I was using :lol: so I tried regular paper, matte photo with different print settings--no improvement.
    So am thinking a damaged head. If so, is a head worth replacing or just buy a new printer? Any thoughts greatly appreciated.
  2. Jul 1, 2015
    martin0reg
    martin0reg Printer Master
    May 9, 2010
    953
    619
    223
    Germany Ruhrgebiet
    Gloryb and The Hat like this.
  3. Jul 1, 2015
    The Hat Printer VIP Moderator
    8,811
    3,362
    363
    Wicklow Ireland
    Printer Model:
    Canon Rule in My House
    Hi @Gloryb and welcome, now for the bad news ! :(
    I can only concur with @martin0reg and say the print head has failed on half of the cyan nozzles and no amount of cleaning is going to fix it.
    Now if you can somehow find another print head for your iP4300 then get one and ignore the cost because you won’t find another printer like it again, it is worth saving and will reward you with many more years of service.
    It will still work for all your black only text documents..
    Gloryb and jimbo123 like this.
  4. Jul 1, 2015
    Gloryb
    Jun 30, 2015
    21
    Texas
    Printer Model:
    Canon IP4300
    Thank you both for the informative and rapid responses! Canon also 'relooked' their response and now say it sounds like an 'internal hardware malfunction'. :hit
    Replacement heads start at $40--I paid $90 for the printer so guess it's time to start searching for another plain, simple, reliable printer if they exist. You both have a point in that I can, and will, continue to use the printer for text documents until the ink runs out or the printer blows, whichever comes first. Thanks for taking the time to respond.
  5. Jul 1, 2015
    fotofreek
    fotofreek Printer Master Moderator
    Nov 5, 2004
    1,811
    433
    San Francisco
    If $40 brings the printer back to proper function it is a risk I would take. Be sure, however, that the replacement head you buy is new in the factory packaging and not used or "refurbished". As an aside I've purchased two used ip4300's on Craig's list (San Francisco Bay Area) in the last two years. Both were minimally used, with OEM inks only, and tested perfectly. I gave one to my granddaughter, along with OEM carts prepared for refilling as well as refill ink, squeeze bottles, and a resetter. I cleaned the print head for storage and put the second printer away as a spare for the inevitable lack of use/failure of the first ip4300 that a young teenager will experience.
    PeterBJ, Gloryb, palombian and 2 others like this.
  6. Jul 1, 2015
    palombian
    palombian Print Addict
    Feb 4, 2014
    543
    589
    187
    Belgium
    Printer Model:
    Pro9500II MX7600 IX6550 MG8250
    If you plan to use the printer (in fact the head) for B&W only you must mask the cyan color contact on the printhead connector, if not you will have a printhead error soon and even burn the printer logic board.
    Lukasz explained this in detail.
    Gloryb likes this.
  7. Jul 2, 2015
    Gloryb
    Jun 30, 2015
    21
    Texas
    Printer Model:
    Canon IP4300
    Good point if indeed the problem is the print head. I will shop around and see what is out there. Sure would be nice to get a few more years out of this workhorse. Thanks for the tip.
    The Hat likes this.
  8. Jul 2, 2015
    martin0reg
    May 9, 2010
    953
    619
    223
    Germany Ruhrgebiet
    I have bought refurbished printheads for ip4000, because it seems these are not available anymore as new. They are running without issues so far ..
    To buy a used printhead or a printer from private has the same risk.
    So if the description is correct, not offered as "new" though it is used, you might give it a try - if there is no new QY6-0061 to buy. But beware there is no garanty, hopefully the seller offers a refund if it's not working..
    PS sometimes there are even cheap "black" printheads, but these are probably worse than yours..
    Gloryb likes this.
  9. Jul 3, 2015
    fotofreek
    Nov 5, 2004
    1,811
    433
    San Francisco
    Absolutely right, Martin. I only bought used printers if they 1)had only used OEM ink, 2)had OEM carts in place with enough ink to run a test, and 3) if I was able to bring photo paper and a test picture to the seller's place to run both a nozzle test and do a test print.
    It did cut the risk down substantially, and if the price was right and the printer didn't work out I still ended up with a set of OEM carts to set up for refilling. One must have great patience to scan through Craig's list for the one gem out of a lot of clunkers! I'd only buy one from someone in my direct area so I wouldn't waste a lot of time going to check out a printer that didn't measure up to my criteria.
  10. Jul 3, 2015
    msmart
    msmart Print Addict
    Apr 23, 2009
    279
    55
    158
    Arizona, USA
    Printer Model:
    Canon iP4500
    Yes, craigslist is great. I've bought several of my iP4500s that way for less than the price of a new printhead. Once I validate that the printer works (no chance to test it out when the transfer is done in a parking lot), I use the printhead in my very first (and only one used) iP4500.
    They don't show up much there any more and prices are outrageous on eBay. I've looked, a few times, for them in Goodwill stores but haven't seen any.
Share This Page
