- Feb 24, 2005
- Location
- North of Boston, USA
- Canon i9900 (plus 5 spares)
I have been keeping a detailed record of the number of pages printed and when carts are changed for the last 10 weeks. The number of prints is recorded as the "Number of 8x10s" by counting three 4x6 prints (printed three to an 8.5x11 sheet) as one 8x10 (72 sq in vs. 80 sq in) and one 12x18 print as two 8x10s (216/2=108 sq in vs. 80 sq in). The 4x6s are 10% under the print coverage of an 8x10, but the 12x18s are 35% over. Given my average usage of these sizes, the unders balance out the overs fairly well, so the "8x10 equivalent" is fairly close.
Even though I refill, the printer is always run until it reports a cart as "empty" and refuses to print any more. The point at which any cart is reported as "Low" is also noted, but only to log the point when this occurs. With a large supply of spare (already refilled) carts, an empty cart just requires a simple cart swap. The carts are never inspected between changes, relying on the printer to indicate when one of the ink chambers is empty (a "Low" warning). However, when any cart is replaced, every other cart is inspected and replaced if there is less than about 3 mm of ink remaining in the ink chamber. The "Low" carts are replaced at this time because an extended cleaning cycle is run when any cart is replaced (the printer sees that the ink chamber of a "Low" cart now has ink). This cleaning cycle uses a lot of ink and can cause previously non-empty carts to become empty before anything is even printed.
During the last refill cycle a total of 23 carts were refilled and the carts were weighed before and after refilling to get an accurate idea of the ink usage.
A summary:
1. The carts are always filled as full as possible in both the sponge and ink chambers. Some people say this can cause ink delivery problems, but I haven't seen any problems from this practice.
2. The refilled carts took (on average) 8.7 grams/cart to refill. Since the ink's density is about 1 gr/CC, this is about 8.7 CCs/cart.
3. Two carts were completely purged and dried before being filled, and they averaged 16.5 CCs of ink/cart. This indicates that up to 8 CCs of ink can remain in an "Empty" cart, but this value would be lower if the sponge wasn't completely full on a prefilled cart (OEM and some 3rd party prefilled carts).
4. The "average" ink usage is very close to one cart for every twelve 8x10 prints. At the current $12 list price for OEM BCI-6 carts, this give an ink cost of about $1.00 for each 8x10 print with OEM inks. The ink cost is about $0.06 for the same quantity of 3rd party bulk ink and $0.20 for 3rd party prefilled carts.
5. Using 9 CCs/cart, this gives an ink usage of 0.75 CCs/(8x10), or about 0.6 CCs/(8x10) if you deduct a 20% ink loss for cleaning cycles (startup./shutdown/cart changes/etc.). The 20% value wasn't measured and is only an estimate based on what I have seen elsewhere for a printer with a high usage and no extra cleaning cycles.
6. The red, green and black usage was so low that it is impossible to know whether any ink was actually used for anything other than cleaning cycles.
7. The usage reported here is based on my prints, and will vary if your prints tend to be lighter (I tend to edit my photos a little darker than most) or of lighter subjects (prints of children playing against a background of grass/trees tend to use a lot of color). It is also probable that other inks will require either more or less ink, depending on their coverage.
8. The following are the approximate ink usage on an i9900 8 color printer in CCs per 8x10 high quality photo print for each ink (these values include the losses during cleaning cycles):
PM 0.23
M 0.064
PC 0.17
C 0.056
Y 0.13
K 0.033
G 0.033
R 0.033
As a point of interest, a 2 pl printer using 0.23 CCs of PM ink will generate 115,000,000 individual PM dots of ink on a typial 8x10 print - enough to print a dot every 30 microns in both direcions.
9. The following are the average number of 8x10 sheets that were printed after a "Low" signal and before the "Empty" signal was given. There are no good values for the inks with a low usage rate - they were always replaced before they ran empty because one of the other colors (usually PM or PC) ran "Empty" first. The values for the PM, PC and Y aren't consistent with the rate of ink usage.
PM 3
M >15
PC 8
C >15
Y 6
K >15
G >15
R >15
10. There was one time period when the printer was unused for 2 weeks (it was turned off). There was a long cleaning cycle when it was turned back on, but there was no sign of any printing problem even after 2 weeks of idle time. In fact, there has not yet been the need to run any extra cleaning cycles for any reason since switching inks, Over 40 carts have been changed during this time and a total of almost 500 8x10 sheets printed.
A summary:
PM 0.23
M 0.064
PC 0.17
C 0.056
Y 0.13
K 0.033
G 0.033
R 0.033
PM 3
M >15
PC 8
C >15
Y 6
K >15
G >15
R >15
