Ink refill tool
Andrew Wood
Wigan, UK
HP Sprocket Photo Printer
Hi,
I want to know which ink refill tool is best for any printer. Can we refill ink without calling any specialist using ink refill tools?
@Andrew Wood, I’ll attempt to answer your questions as best I can !
All inkjet printers use a different way and special tools to refill, some are very easy to refill and some a little bit more difficult, they all differ.
Ink is specific to certain printer models and should be matched by colour and viscosity to each different printer manufacturer, otherwise your printed output will look very odd, or not print at all after a very short while...
CakeHole
United Kingdom
Canon MP610
What model of printer and model of ink carts do you require information about?
Refill methods differ model to model, so without that info first nobody will be able to help in any depth.
Andrew Wood
Wigan, UK
avolanche
East Tennessee
Y
Hi,
I am using Canon Pixma printer and quality of printer is very good. I have researched online and found these sites to refill ink cartridges manually:
http://www.goinkjet.co.uk/
https://www.inkowl.com/index.php?C=10&S=19
http://www.rjettek.com/refilling-tools/
I think tools selling above sites will help me to refill ink into my printer.
You might want to check out Octoinkjet and Precisioncolors. Both are excellent sellers and both post on this forum regularly.
Andrew Wood
Wigan, UK
Which model Canon Pixma? There are many different models with different cartridges and different refill methods.
Here is printer model: Canon PIXMA MG7720
CakeHole
United Kingdom
Canon MP610
Your printer uses 271 and 270 series of carts you can either refill them via a top method like most Canon carts or use a custom tool like this...
https://www.youtube.com/watch?v=cyCZHo8sNa0
That video also includes weights of the cart and amount of ink to refill with.
If you wish to top fill follow this video...
https://www.youtube.com/watch?v=GaxI2QPWLWA
AFAIK you can not reset the chip on this model yet.
EDIT: actually you can....
http://www.octoink.co.uk/products/Canon-CLI%2d570{47}PGI%2d571-Redsetter-[USB].html
For if you and your printer are from Europe
and
http://www.octoink.co.uk/products/Canon-CLI%2d270{47}PGI%2d271-Redsetter-[USB].html
For if you and your printer are from America
Alternatively you can purchase a set of refillable carts like these...
https://www.youtube.com/watch?v=Qxt2bP2ug7Y
I trust that about covers it :)
I wonder, is this type number really correct? The printer type number is for the North American model (intended for use in USA and Canada). The Model intended for use in Europe is Canon Pixma MG7750. Did you import the printer yourself or bring it with you from North America? The North American model will only work with cartridges and chips and resetters marked PGI-270 or CLI-271. The cartridges, chips and resetters for the European version are marked PGI-570 or CLI-571. Accessories for the European model will not work with the North American model and vice versa.
