I am just guessing at this as I do a lot of woodworking, many stains and finishes go bad quickly after opening..
What WW use to stop this is http://www.bloxygen.com/
But an old time trick is to hold your breath and then blow air into the can to drive out the oxygenated air and replace it with CO2
Oxygen is that you dont want, I also seen an artical about adding small clean stones to a 1 gal can so it stays full with liquid and no air is another option..
I am not sure if it is oxygen that causes ink to spoil but its worth a try..
Hope this helps someone..
