Getting a colour laser duplex
flyboy
Canada
Epson ET-3750 + 27" iMac Retin
I am looking for a color, duplex printer that can do wired connected.
My initial guess is to start with Costco.ca who sells ;
Brother MFC-L3765CDW Digital Colour Multifunction Printer - 630 CanD​
HP 4301dw Wireless Colour LaserJet Printer - 640 CanD​
Any thoughts on which or any of these who would be a better choice ?
TIA
Al
thebestcpu
Epson SC P900
Hi @flyboy
They sure look very similar.
I usually check and see if there is any difference in the ability to get it repaired when that occurs.
If getting repairs is similar, the main differences I see are that
- The HP has a higher printing speed by about 30%
- The brother could be lower cost per page by 1/2 if using third-party toner cartridges, which can be done while on the HP machine, which is quite complex (not sure if it is possible).
I don't have info on the reliability of either, so that might be worth checking too.
You did not mention your page volume per year. If it is relatively high, I might lean towards the brother for the overall lower costs considering third-party toner cartridges.
Just to let you know, that is my view as a potential consumer, not as an expert on laser printers.
John Wheeler
thebestcpu
Epson SC P900
Hi @flyboy
I also wanted to include that both of those printers do duplex printing yet not auto duplex scanning. Thought that was important since you included "duplex" in the title of your post.
John Wheeler
flyboy
Canada
Thanks thebestcpu !
I had not considered duplex scanning. Not sure I have ever seen that. The Brother aftermarket toner is about 1/2 or less the price.
My page volume per year is not huge, but never really checked. Funnily enough if I had bought the Brother the day I posted, it was on sale for about 150 less @ Costco.
I had heard that Brother was making pretty decent printers but never knew much more than that.
I used to use HPs a long time ago but they were very expensive to operate and when they decided that the printheads were done the machine would just stop. That happened at a very inopportune time, as I needed some paperwork to get on a series of flights. So no more of them for me.
Their print quality was always excellent tho.
Then I got an epson and the print quality was/is not the best, but I liked the Tank rather than the cartridges and my printing quality is not an issue. I almost never run the colours so they have partially dried out and taking the printhead out and flushing has not helped much. I need decent colour quality now so I figured time to try a laser printer.
I also have noticed that running B&W all the time is not a good idea as the colours start t dry up.
ThrillaMozilla
Thanks thebestcpu !
It is very handy if you ever need it.
Probably still very high. But Brother has the reputation for being reliable and long-lasting, and maybe economical printing.
Laser printers probably won't do very well for color photos on office paper, and as far as I know you can't even use them on photo paper. But inkjets, as you know, are expensive to run, and require regular use or maintenance.
Redbrickman
Brother MFC-L8690-CDW
Just make sure the one you buy can work with refills or 3rd party toners. Many of the newer printers are well locked down to their manufacturers toner :(
The main reson why I bought a Brother MFC-L8690-CDW. It's huge but carts are easily refilled and can get cheap 3rd party carts.
flyboy
Canada
Thanks to everyone!
I bought the Brother MFCL3765COW.
It works well and the yellow cartridge just ran out. So i am looking at refilling it.
I found a refill kit on amazon. I've had lots of experience on refilling ink-jets with a variety of schemes, which culminated getting the Epson 3750 system which works well.
Is the refilling process a big deal? This guy explains it quite well and it does look reasonable. Is cleaning or lubricating a good idea or is there other things to do?
Redbrickman
Some printers will tell you the cart is empty when it is not (sneaky marketing).
This video explains it and what to do. It's not your machine but the prociple is probably the same, though check that there is a way to reset the gear wheel as shown in the video. Try it and see if you get some more use out of the cartridge, or just refill it as you planned to do.
I also think its a good idea to buy a set of compatibles as then you will have a spare set to refill.
Also a lot more machines here so you may find one that is the same as yours when refilling
https://www.youtube.com/@urefilltonerUK/search?query=brother
