framed prints fogging
pm
Whats up with my framed prints fogging up? I've got serious fogging problem on three quaters of my most recent framed work, These were on display outdoors and after two days a noticed this film on the inside part of the glass, The pieces were not in direct sunlight how ever it was quite hot out. How can this be avoided. HELP!!!!!!
bobglen97
Questions for you
Printer mafg/model/ink/paper?
allowed dry time before framing?
framed with mat?
framed indoors/outdoors?
Temp/humidity delta between indoor/outdoor?
fotofreek
San Francisco
Bobglen raises an important issue. With many printers and the combinations of ink and paper, prints come out of the printer dry to the touch. They are not completely dry, however, and need to be left exposed to the air for 24 hours or so before storing or framing. probably condensation on the inside of the frame glass. You can probably take the print out and leave overnight, clean the glass, and reframe the print.
pm
I've got a Canons9000 with the canon inks. Prints take about 24 hrs to set up,also these were not framed and matted for 4/5 days after printing. I took the print out of the frame and this film was everyware onthe glass but wear the matt was, The film has almost a patternlike appearance to it. Looks like the ink gives off a gas in certain weather conditions / warm 80 to 90 degrees not to humid 60% or so.
pm
I just read about the out-gasing problem. thats my issue, Now what kind of paper do you lay over the print for a quicker curing time?
Grandad35
North of Boston, USA
Canon i9900 (plus 5 spares)
pm,
The paper must be porous, so this rules out photo paper or coated paper. It also can't stick to or discolor the photo, so this rules out newspaper (or any printed paper). The first link recommends regular bond paper used for text printing - I use it to interleave between my prints when I have a large stack of fresh prints that must wait to dry.
Manuchau
B.C. Canada
I would think that since matte paper is more porous, you'd have better results with it.
I had some framed prints I had done a while ago for a fair, and had a similar problem.
The matte prints didn't fog up.
Good luck!
