1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: CLI-42 cleaning fluid
    CLICK HERE!
    Dismiss Notice
Epson SureColor P600 Colour Ink Consumption
Discussion in 'Epson InkJet Printers' started by BirdWife, Apr 11, 2019.
  1. Apr 11, 2019
    BirdWife
    BirdWife Newbie to Printing
    Apr 11, 2019
    Printer Model:
    I have a Epson SureColor P600 printer that I ONLY use to print gray scale. The all cartridges that are currently in it are the originals that I put in when I received this printer in January 2019 (It is a refurbished printer to replace one which I purchased in June 2018). The three black cartridges (I dont use the glossy black), are going down in amounts that I would expect, however the colour ink is also going down, all at varying amounts. I understand that every time the printer is turned on and it prints a "small amount" of colour ink is used to clear the print heads so that they dont clog. What I do not understand is why some of the colour ink is being consumed at the same rate as my black ink, while other coloured ink is barely being used. Using Epson's logic, all colour ink should be being consumed at the same rate if it is only being used to clear the printer heads.
    I called Epson to ask them about this and they gave me some excuse saying that the colour ink is being consumed in this manner because I am using the smaller volume cartridges that my printer came with. Once I switch to full size cartridges this will no longer happen and the colour ink will be consumed at a consistent rate across all 5 cartridges if I continue to only print gray scale.
    To me this makes little to no sense - why would the volume (size) of the cartridge affect how the ink is being consumed? I have attached a picture for reference.
    Is Epson correct and I am out to lunch?
  2. Apr 12, 2019
    Ink stained Fingers Printer Master
    2,986
    3,122
    Printer Model:
    L310/382/1800, P400, Pro7600
    I rather think that small amounts of colored inks are used even if you print grayscale, this to offset small color shifts of the black and gray inks. The driver is doing such corrections based on the various driver options. The driver is converting the image into grayscale but still uses some of the colored inks together with the gray inks. Just to give you an example - I'm using a P400, and if I load the matte black cartridge with a clear ink/cleaner and print black it is printing cyan , printing the matte black ink without that cyan byprint it would have a brownish black look, and not a neutral look. And I can give you more examples for such embedded color corrections. Black or gray inks still have a color tint which gets corrected by the driver.
    (I won't comment on the competence of support lines )
  3. Apr 14, 2019
    BirdWife
    Apr 11, 2019
    Printer Model:
    Thank you very much for your reply. I heard something very similar from someone else, and your explanation, as well as theirs makes total sense to me. I wish the Epson Representative that I spoke to would have just told me this...
    The Hat likes this.
  4. Apr 17, 2019
    Julia
    Julia Printing Apprentice
    Jan 2, 2019
    17
    8
    16
    Printer Model:
    Epson Surecolor P400
    Can I ask...when (The Hat) you say that 'if I load the matte black cartridge with a clear ink/cleaner and print black' could you explain what that means and why you would do that?
    Are you using other than Epson Inks? Or have you some other ink delivery system?
    Always learning ! Thanks, Julia
    NB re rates of ink use...orange seems to stay forever while cyan and magenta disappear fast, yellow coming in second along with one of the blacks. But then, I am printing colourful stuff.
  5. Apr 17, 2019
    The Hat Printer VIP Moderator
    11,324
    5,180
    403
    Wicklow Ireland
    Printer Model:
    Canon were, BUT 3D is better..
    ? ?...:hu
  6. Apr 17, 2019
    stratman Printer VIP Platinum Printer Member
    5,938
    4,091
    Printer Model:
    Canon MP830, Pencil
    If my The Hat decoder ring is functioning again...
    I think what The Hat is trying to say, in this uncharacteristic minimalist way, is it was Ink Stained Fingers that posted that and who you need to direct your questions towards.
    The Hat likes this.
Share This Page
