- Dec 27, 2014
- Location
- Germany
- L805, WF2010, ET8550
I did a test with the help of @palombian to compare the print output of these two printers - mainly how do the printouts compare - how do they look - how does the gloss/chroma optimizer perform. We both printed several test images with our printers - on the same Sihl glossy photo paper - with the inksets we are currently using, and we exchanged these prints by mail so that the other could judge and compare the output to his own prints.
I'm running an Epson P400 printer, the only one in the Epson line-up which supports the use of a gloss optimizer as Epson calls this clear liquid. I did several tests over the years how I get the best looking (by personal judgement) output in the combination of inks, papers and various GO brands - see my last posting here
https://www.printerknowledge.com/th...gloss-optimizers-for-epson.13795/#post-119740
I'm curently using the GO of a Chinese (via Aliexpress) supplier 168ink.com which I got some time ago, and I'm using a mix of pigment inks from previous tests - a mix of Pigmera HG2 by farbenwerk and some Ultrachrome HD inks, I'm mixing red and orange with yellow and magenta, this reduces the amount of non standard ink bottles floating around although it may impact the acheivable gamut to a degree. Since the gamut does not just depends on the supplier but very much on the paper type as well I'm not evaluating gamut differences very much at this time in this test, that would be another more complex exercise. I'm printing the test images with the GO turned off at the time of printing , and do a separate full page overprint with GO some time later. This turns out to deliver the best looking prints.
I'm comparing the Epson vs. the Canon prints - they look very very similar - they show the same uniform gloss - across different colors - and as well in the highlight/clipped white areas. I'm comparing prints done with a non-standard/non-genuine inkset, on a non-Epson paper with a non-Epson gloss optimizer, I'm comparing against prints which are done under similar conditions on a Pro10 - non-Canon inks on the same non-Canon paper by @palombian. I think it would be impossible for other observers to tell the difference - which is a Canon or Epson print - I'm not talking about a magnifier view to pixels and ink dots - dithering etc.
He explained in another recent thread in detail his efforts to optimize the ink set for his Pro 10
www.printerknowledge.com/threads/my-canon-pro-10-on-refill-ink-and-what-happened-to-my-pro-9500ii.13542/page-16
I don't have OEM Epson inks available nor Epson papers so I'm not able to do such comparison, and I will not spend any money for that. The Epson HighGLoss2 ink for the P400 is not even available in larger Epson cartridges since it is not used in any other larger printer model.
Edit:
Edit:
