1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: Macbook pro doesn't connect to IPF6400
    CLICK HERE!
    Dismiss Notice
Epson Inkjet Printer, all Lights blinking Solutions
Discussion in 'Everything Else' started by PRINTER SOLUTIONS24, Sep 4, 2018.
  1. Sep 4, 2018
    PRINTER SOLUTIONS24
    PRINTER SOLUTIONS24 Newbie to Printing
    Jul 4, 2018
    Printer Model:
    HP M401dne
    if you have all lights flashing and your inkjet Epson printer reporting a possible paper jam or fatal error but there is no paper jammed in the printer maybe the problem is the light sensor.
    first of all, look at the waste ink pad counter to be sure the problem aren't the waste ink pads try to change all ink cartridges if the error remains try this turn off the printer and remove the power cord open the printer cover the light sensor is here check if it's clean some ink or debris might have cover the sensor if it appears clean move the print head carriage to the left remove this screw remove the metal cover this is the light sensor gently clean the sensor with a soft cloth if needed it's possible to remove the sensor remove this screw lift up the sensor reinstall the sensor reinstall the metal cover reinstall the cable and check if the printer is working.
    PRINTER SOLUTIONS
    All Brand Printer Support
Share This Page
