1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: How to take pictures of gloss differential properly?
    CLICK HERE!
    Dismiss Notice
Epson Ecotank inks usable in Canon iP7250?
Discussion in 'Member Introductions' started by CapoKees, Oct 11, 2016.
  1. Oct 11, 2016
    CapoKees
    CapoKees Getting Fingers Dirty
    Feb 21, 2015
    11
    13
    45
    Delft
    Printer Model:
    Epson R3000
    Hello members of this nice forum, as I wrote already in the titel of this thread should this be a possibility ?
    I have read the thread of fading of some dye inks which gave as result that these Ecoinks are almost as good as Epsons Claria inks.
    I tried different refill dye inks but all suffer of fading, colourcast and/or a great difference in saturation compared tot the original Canon ink.
    Thanks in advance.
    Kees.
  2. Oct 12, 2016
    jtoolman Printer Master Platinum Printer Member
    May 7, 2011
    1,944
    926
    237
    Printer Model:
    Not a good idea. Canon print heads expect inks with the correct viscosity and these Epson inks are likely to not be what a thermal canon head expects.
    Would likely cause permanent damage!
    Joe
    The Hat and Ink stained Fingers like this.
  3. Oct 12, 2016
    Ink stained Fingers Printer Master
    2,199
    2,209
    243
    Printer Model:
    L310, L382, L800, Pro 7600
    It won't work this way, Canon inks would print in Epson printes, but not the other way around, I tried it long time ago.
    Typical budget 3rd party inks all suffer from limited light fastnesss, a long thread with tests etc was dealing with this issue - with Epson inks
    http://www.printerknowledge.com/threads/which-pigment-ink-for-epson-1500w.9323/page-23#post-94204
    The choices for Canon refill inks are very limited, martin0reg is currently running a test with a Fotonic XG Lyson ink here
    http://www.printerknowledge.com/threads/refilling-canon-with-oem-ink.10712/page-5#post-93826
  4. Oct 12, 2016
    martin0reg
    martin0reg Printer Master
    May 9, 2010
    1,002
    671
    243
    Germany Ruhrgebiet
    Yes, sadly there seems to be no such ink for canon dye like fuji DL (and a few others) for epson dye.
    Fotonic XG is the most stable in my tests, but it is not the best in color matching... and it's more expensive than the others.
    But there may be no-name compatible cartridges for less than 2€ with astonishing good light fastness, according to this test by Peter BJ:
    http://www.printerknowledge.com/threads/photo-paper-at-aldi-dk.10719/page-3
    Problem is where to get these specific carts with this specific ink, because there is no information about the manufacturer.
    Beside these I remember that compatible carts from "Peach" had some good test results, here is a test from 2013:
    http://www.druckerchannel.de/artikel.php?ID=3338&seite=9&t=die_lichtbestaendigkeit
    The Hat likes this.
  5. Oct 12, 2016
    CapoKees
    Feb 21, 2015
    11
    13
    45
    Delft
    Printer Model:
    Epson R3000
    Thanks Joe, Martin and Ink Stained Fingers,
    I understand your comments so I think that it should have been better buying an Epson instead of the IP 7250.
    Bought this Canon and gave away my MG5550 tot my granddoughters for schoolwerk.
    Therefore I still had some carts and ink which was the reason tot stay with Canon iP7250.
    Another idea:
    Will the Epson Ecoink work in other Epsons than only the Ecomodels or blocked Epson this?
    Maybe this could be a possibility but than again I have to buy a new printer and refillcarts!
    Thanks again very much, wish you all happy printing.
    Kees.
  6. Oct 12, 2016
    2,199
    2,209
    243
    Printer Model:
    You may use the Epson bottled ink other Epson printers with suitable refill carts, but I wouldn't see too much benefit with that approach. The benefit of the Ecotank Epson printers is the convenience with refilling, much less handling, less ink wasted with otherwise regular cleaning cycles after every cartridge change/refill, the more you print the more you'll recognize this. You may as well use other 3rd party refill ink with these Ecotank models. Regrettably the model choice with their features is pretty much limited by Epson, Epson is offering some ET... Ecotank models in Western Europe, and a few more in the eastern countries which you can get only via gray imports by companies shipping from Czechia or Poland. The first generation was a range of L... models with an ITS - integrated tank system, and the ET.... models are the 2nd generation with some changes to the attached ink tanks.
    The Hat likes this.
  7. Oct 13, 2016
    CapoKees
    Feb 21, 2015
    11
    13
    45
    Delft
    Printer Model:
    Epson R3000
    Well that is right but putting the Ecoinks in eg a XP 332 save you at least € 200.
Share This Page
