Canon PRO 300 5B00 error
cosmingheorghe
Print Lurker
Canon PRO 300
Hello! I have a canon PRO 300 that displays error 5B00. I contacted a service, and the people there told me that there was nothing more I could do. Can I still solve this problem? Thank you!
L805, Pro7600, WF2010,ET8550
cosmingheorghe
Print Lurker
Canon PRO 300
This is the documented Canon response to the 5B00 error if you are out of warranty
https://support.usa.canon.com/kb/index?page=content&id=ART179094
You probably can find inofficial resetters like this one
https://www.impresorastotal.com/reseteo/resetear-impresora-canon-imageprograf-pro-300/
(Use Google translate if needed)
But such resetter won't replace the waste ink pads/storage elements
I used the reset program and it worked perfectly. Thank you very much!
palombian
Belgium
PRO10,PRO9500II,MB5150,MG8250
The second link suggest downloading a service tool.
This is how to reset the ink counter, but take care about the version number.
Only versions dated after the release of the PRO-300 are susceptible to work.
Others will block all further access.
FYI: this is (an evaluation copy of) version 5103 from 2018
The version for the PRO-10 already had number ST5204, I wouldn't dare.
You will have to pay a few bucks for a reliable hack.
Search on eBay, I've seen version 6000 (no guarantee but much more chance).
Do your research, good luck and report back.
PS: the ink absorbers will not overflow the next day, this is something to tackle later.
Going to ask the question... Has anyone actually pulled a Pro300 apart to work out how to change the pads or fit an external waste ink tank?
Alternatively has anyone done the same on a Pro200? Asking as I may have the opportunity to do just that but I'd rather follow in someone elses footsteps if at all possible as I suspect I'll end up wrecking a unit if I don't have some clues in advance.
Similarly access to a service manual while unlikely would be very welcome, if anyone knows of a source.
Artur5
Kmt. 0.
This seems to be an unexplored territory. AFAIK none of the regulars here owns these printers, so you'd have to be a pioneer and endure the foreseable mistakes... :rolleyes:
Have you searched on Youtube ?
As for a service manual, PeterBJ is the expert, but I suspect that the only place to look for it is Canon's vaults
