1. Dismiss Notice
  2. Picture Of The Week (POW) Information and Submissions
    CLICK HERE!
    (if you are logged in, this notice can be dismissed using the "x" to the top right of the notice)
    Dismiss Notice
  3. Official PK Poll: Is there any future in refilling?
    CLICK HERE!
    Dismiss Notice
  4. PK Featured Thread: CLI-42 cleaning fluid
    CLICK HERE!
    Dismiss Notice
Canon IP4300 Test Page - What Does It Mean?
Discussion in 'Canon InkJet Printers' started by FTD, Jan 19, 2015.
  1. Jan 19, 2015
    FTD
    FTD Printing Apprentice
    Jan 18, 2015
    12
    Printer Model:
    ip4300
    I have a IP4300 that is several years old, and has been sitting unused for about six months. Foolishly, I let it sit rather than printing an occasional page or two. I left the cartridges in the head thinking it would be best to keep ink from drying on the screens, but drying of the ink in the heads caused some blockage as seen in the pattern on the first test page I posted. To try and open up the heads I soaked the head in warm water for a few hours with little success. I then tried resting the print head on a Windex soaked paper towel, and adding drops directly to the screens repeatedly as it flowed through. After about two hours I rinsed the head with water and tried printing again. The pattern improved greatly, but there still are a few lines missing on the grid pattern. I repeated the Windex soaked paper towel twice, first for two and then about four hours... no improvement. What I am wondering is what the pattern shows? No matter how many test pages I print, or ink cleanings I run, the pattern is always the same. So does this mean a single specific jet is blocked, or since there are four lines missing that four jets are blocked, or does it mean something completely different? In general if I print a text test page it looks O.K., but there is occasionally a dark line in the other colors (for example if I print the Google home page there will be a thin dark line running through "Google"). In addition, now after each print I hear what sounds like the cartridges purging. I don't remember that happening so frequently before.
  2. Jan 19, 2015
    turbguy
    turbguy Printer Master Platinum Printer Member
    Sep 10, 2007
    1,457
    1,153
    Laramie, Wyoming
    Printer Model:
    Canon i960, Canon i9900
    EACH horizontal line represents one nozzle. So four nozzles are "at issue".
    You may still have clogged nozzles in the Pigment Black ink grid. OR, those nozzles have become inoperative.
    Good to see that light cyan recovered.
    I'd let it sit for a day or two, and try again. You may need more aggressive cleaning, such as forcing windex through the Pigment Black inlet screen with a syringe...
    The Hat and PeterBJ like this.
  3. Jan 19, 2015
    Smile
    Smile Printer Master
    Aug 23, 2006
    1,734
    375
    Europe EU
    Printer Model:
    Soak it longer, it will clear up if the nozzles are undamaged.
    The Hat likes this.
  4. Jan 19, 2015
    The Hat Printer VIP Moderator
    11,318
    5,177
    403
    Wicklow Ireland
    Printer Model:
    Canon were, BUT 3D is better..
    I would tend to agree with @turbguy and @Smile but I would also look into getting some new or replacement cartridges..
  5. Jan 19, 2015
    Harvey
    Harvey Printer Guru
    Dec 24, 2010
    151
    26
    138
    This is from a recent post. I had problem with pigment black being inexistent in the nozzle check pattern, I have seen this inexistent problem twice and this is what I did. Now your problem is not so bad as some nozzles are the ones with the problem. This could be helpful assuming that your pigment cart is Ok with no flow problems.
    My failure proof method is to boil water, (not in the microwave), place the printhead horizontally so the nozzles are facing to you,(for some precautions I covered with toilet paper the openings above the inlet ports this in order to avoid water or steam wetting the printhead board) and then you fill any syringe (a 50 or 60 cc is better for the time you keep spraying water on the nozzles, remove the needle to fill it then attach the needle, this way you avoid long wait time filling and the water is still hot;)) and pour the content on the nozzles of pigment black in a sweep and slow motion from top to bottom. Also with the same syringe spray water in the inlet port and the purge pad. (Only boiling water cleared the filter in the purge unit without removing it).
    It is important to apply great pressure to the plunger to make this more effective. I think this is the principle of pressure washer which loosens the pigment particles in the nozzles with pressure aided whit hot water.
    I am pretty sure this won´t fail. Perfect nozzle check guaranteed. :weee
    Note: You can mix water with Windex if you wish in a 1:1 ratio, using distilled water is better to avoid sediments or minerals in tap water. All these steps are optional.
  6. Jan 19, 2015
    FTD
    Jan 18, 2015
    12
    Printer Model:
    ip4300
    Thank you all for the replies. I had loaded new cartridges after I cleaned the head the first time, so I should be good to go there. I will try the power washing, and if it doesn't work, let the head soak for awhile.
  7. Jan 19, 2015
    11,318
    5,177
    403
    Wicklow Ireland
    Printer Model:
    Please don’t be tempted to let boiling water anywhere near your print head or your cartridges because it will damage them both, you can however use hand hot water safely..
    Smile, jimbo123 and PeterBJ like this.
  8. Jan 23, 2015
    Paul Verizzo
    Paul Verizzo Print Addict
    Apr 16, 2011
    385
    75
    153
    Sarasota, FL, USA
    Printer Model:
    I've gone higher temp than "hand hot" w/o issue. The almost boiling water was only at the nozzles, nothing above. Not going to claim that the very hot water was the trick, but we all know most chemical reactions, i.e. destruction of molecules, is hastened at higher temperatures.
  9. Jan 23, 2015
    turbguy
    Sep 10, 2007
    1,457
    1,153
    Laramie, Wyoming
    Printer Model:
    Hand hot is about 135 degrees F. Most of the sensitive electronics are microcircuits integrated in the nozzle plate structure immediately adjacent to the nozzle openings. I believe there is some risk using boiling water at 212 degrees F (or 192 degrees F at my elevation) on such components, but YMMV...
    The Hat likes this.
  10. Jan 24, 2015
    Paul Verizzo
    Apr 16, 2011
    385
    75
    153
    Sarasota, FL, USA
    Printer Model:
    Granted, I didn't put a thermometer in the water, so maybe "almost boiling" was a bit of exaggeration. It was microwaved until "sorta steamy"? If you've ever had a rapid response thermometer in some water, especially of not much volume, the temperature falls extremely rapidly.
    So, just carrying those few ounces of water from the microwave to the counter, and by the time I put the head in, it surely lost 15-20 degrees..........from wherever it was.
Share This Page
