Canon i965 print head totally blocked
theskid
LANCASHIRE,ENGLAND
i have been refilling cartridges for a bit they, probably need cleaning but they are not too bad
the problem is my i965 print head will only print the yellow cartridge out of 6 put it on deep cleaning a lot of times no ink is being used i also tried this with cleaning cartridges to no avail it will just not clear
so i have ordered some bottled cleaning solution with shringes and i was going to shringe it in the sponge holes on the print head and leave over night or even soak the print head in the cleaning solution (will this be ok and not damage the print head if some of the electronic ciruit tracks were to become into contact with the cleaning solution?)
Please advise as i am a novice
P.S also i am from the UK and have not seen any of these plugs around here my method was to drill a hole in the cartridge then re seal will silicone sealant it seemed to work with the odd leak here and there if you can point me to somewhere in the UK where i could obtain refilling products like these plugs ect thankyou
